I am new to using skyfield
, is there any doc or help file that can show me on how to get the orbit of Sun and moon in ecliptic coordinate for a particular date and time. This is a follow up question of this question
- 83
- 5
I cant help you with skyfield, but I usually use JPL Horizons Web interface. No installation required, you can also print it in a text file if you want:
https://ssd.jpl.nasa.gov/horizons.cgi
Otherwise I found the documentation for skyfield: https://rhodesmill.org/skyfield/toc.html
And if nothing of that works, I made a little astropy script for you
from astropy import units as u
from astropy.coordinates import SkyCoord, EarthLocation, AltAz, get_body
from astropy.time import Time
import numpy as np
Create 1000 Timepoints between Time 1 and Time 2 (one year later)
t = np.linspace(2451545, 2451545+365, 1000)
pointlist = []
#Loop through this times
for tn in t:
# For every timepoint, create an astropy_time object
astropy_time = Time(tn, format="jd")
# Get Planet (as string, "earth", "moon", "mercury" etc. in aequatorial coordinates
planet_aequatorial = get_body("moon", time = astropy_time)
#Transform to Barycentric True Ecliptic (relative to the center of mass of the solar system).
planet_ecliptic = planet_aequatorial.transform_to("barycentrictrueecliptic")
# Add a point to the orbit. Every point is described as (longitude [deg], latitude (ecliptic coords), distance (km))
pointlist.append([planet_ecliptic.lon.deg, planet_ecliptic.lat.deg, planet_ecliptic.distance.km])
print(planet_ecliptic.distance.km)
# So pointslist is a 2D array. The rows are all the 1000 points of the orbit
In every point there is 3 columns for [Long, Lat, Distance]
print(pointlist)
You can also save the result with
pointlist = np.array(pointlist)
np.save("results.npy", pointlist)
- 596
- 4
- 23
- 164
- 5
thanks or the reply, it gives me a single point, however i want complete orbit, is that possible, my question may look silly, apologise – Rasika Nov 29 '19 at 17:44
create a list of times (in julian days) with
import numpy as np t = np.linspace(2451545, 2451545+365, 2000)
then loop over the above code but create Time object with
t = Time(t1, format="jd")
instead
– Andres Huster Dec 09 '19 at 22:47 -
can you give me your e-mail or something? i cant post all the code here i think... – Andres Huster Jan 23 '20 at 11:11
Sorry for the late reply, i used it, but the output latitude does not go beyond 2 degree – Rasika Mar 22 '20 at 12:16
skyfield
– Rasika Nov 28 '19 at 10:26
