I'm wondering - how much delta-v do typical geostationary satellites carry with them once they get into the orbit for things like orbital adjustment or movement to the graveyard orbit?
ThePiachu
  • 259
  • Probably more of a Space Exploration question. – Barry Jenakuns Jul 06 '19 at 12:45
  • "Delta-V" is shorthand for an expenditure of energy. The energy required to change the satellite's kinetic energy ( $\frac{mv^2}{2}$ ) depends on the satellite's mass as well as the total stored energy in the propellant. – Carl Witthoft Jul 06 '19 at 14:37
  • I'm voting to close this question as off-topic because it belongs on [Space.SE] –  Jul 06 '19 at 15:05
  • @CarlWitthoft no, delta-v really is meant to express the available amount of velocity change that a spacecraft is capable of, or a maneuver requires. It is a measure of specific energy which is energy divided by mass. It's a bit hand-waving because the mass changes as propellant is depleted, but it's a real thing in spaceflight. – uhoh Jul 07 '19 at 03:10
    @JanDoggen "because it belongs on" is never a close reason. If it's off-topic here then state that it's off-topic here. I agree that a good place is Space SE, but new users reading your comment can get the idea that if they think a question is better asked somewhere else, or they think it "belongs" somewhere else, then that in and of itself is a close reason, which it isn't. – uhoh Jul 07 '19 at 03:12
    I'm voting to close this question as off-topic because it is not about Astronomy as defined in the help center; see What topics can I ask about here?. However, it is a good candidate for asking in Space Exploration SE. You can consider just deleting here and posting there instead, or wait for it to be closed and see if it gets migrated. – uhoh Jul 07 '19 at 04:32
There's a mountain of readily available information, of which the following is one example. From GOES page
edit
There is more information there about the thrust produced, so I suspect you can calculate the total delta-kinetic energy available.
A2100 has been used for over 40 missions and is available in different versions catered to specific mission needs in terms of dimensions and power availability with satellite mass varying between 2,000 and 6,740 Kilograms.
Each GOES-R-class satellite is 6.1 by 5.6 by 3.9 meters in size and has a dry mass of 2,857 Kilograms. At liftoff, the satellite weighs 5,192 Kilograms, loaded with propellants to support a mission of at least 14 years.
GOES-R, S, T, U launches with a propellant and pressurant load of 2,335 Kilograms with Mixed Oxides of Nitrogen and Hydrazine acting as main propellant components and Helium gas used for the pressurization of tanks.
Carl Witthoft
  • 3,813
