I am a bit confused with point 2.d of the IAU's resolution on dwarf planets.
(2) A "dwarf planet" is a celestial body that
(a) is in orbit around the Sun
(b) has sufficient mass for its self-gravity to overcome rigid body forces so that it assumes a hydrostatic equilibrium (nearly round) shape
(c) has not cleared the neighbourhood around its orbit
(d) is not a satellite.
http://www.iau.org/static/resolutions/Resolution_GA26-5-6.pdf
I notice that a lot of websites exclude this point all together? Some of them even rather combine it with point 2.a ? Like over here
Feels a bit redundant, since orbits the sun implies not orbiting a planet?
Or am I missing something here?
cstruter
  • 133
Yes. You are missing the word "Sun". The IAU did not want to tackle the problem of how to categorize exoplanets. There are only eight planets in the entire universe, plus a good number of (five and counting) dwarf planets. An expoplanet orbiting Alpha Centauri is not a planet or a dwarf planet, per the IAU definition. Some hypothesize that the early solar system contained five giant planets, but one of them was expelled. That rogue giant planet, if it exists, is not a planet per the IAU definition.
You are treating the word "orbit" as if it's a mutually exclusive term. It's not. The Earth's Moon, for example, orbits the Earth and it orbits the Sun. But since the Moon is a satellite of the Earth, it's not a planet or a dwarf planet. Side note: the concept of what distinguishes a "satellite" from a non-satellite is not defined.
David Hammen
  • 33,900
  • 74
  • 125
  • Some sites note the inclusion of point d) thanks to charon? Pluto and Charon technically being a Binary Dwarf System? But I guess the Earth System might also be seen as a binary planetary system? – cstruter Aug 25 '15 at 13:27
  • @cstruter - The IAU currently deems Charon to be a satellite, but has left the door open to a reclassification of Charon as a dwarf planet. – David Hammen Aug 25 '15 at 13:34
  • I just thought that orbit would imply its parent? Since obviously we can get more technical and include what the sun orbits as well etc etc etc – cstruter Aug 25 '15 at 13:34
  • @cstruter: It's hard to argue that the Earth's Moon does not orbit the Sun. For example, see http://www.wired.com/2012/12/does-the-moon-orbit-the-sun-or-the-earth/ . The easy way out of this false dilemma is to say that the Moon orbits both the Earth and the Sun. – David Hammen Aug 25 '15 at 13:44
  • Or rather the Earth & Moon orbits a common point of gravity which orbits the sun? – cstruter Aug 25 '15 at 13:47
  • @cstruter: The center of gravity of the Earth/Moon system is inside Earth, about 1000 miles below the surface. (Some suggest that that is, or should be, relevant to some criterion for something or other.) – Keith Thompson Aug 25 '15 at 19:46
  • Yup, the barycenter, something like 4700km down? – cstruter Aug 26 '15 at 06:38
