While I was struggling to understand why I couldn't import NumPy I think that I faced another problem. During the numerous attempts and through various different "solutions" I think that I end up installing two python.
/usr/bin/python --version
Python 2.7.6
renan@renan-1215B:~$ which python
/usr/local/bin/python
Now when I try to import NumPy the following error appear:
>>> import numpy
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ImportError: No module named numpy
Everything seems to be installed
renan@renan-1215B:~$ apt-cache policy python-numpy
python-numpy:
Installed: 1:1.8.2-0ubuntu0.1
Candidate: 1:1.8.2-0ubuntu0.1
Version table:
*** 1:1.8.2-0ubuntu0.1 0
500 http://br.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
100 /var/lib/dpkg/status
1:1.8.1-1ubuntu1 0
500 http://br.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
renan@renan-1215B:~$ apt-cache policy cython
cython:
Installed: 0.20.1+git90-g0e6e38e-1ubuntu2
Candidate: 0.20.1+git90-g0e6e38e-1ubuntu2
Version table:
*** 0.20.1+git90-g0e6e38e-1ubuntu2 0
renan@renan-1215B:~$ apt-cache policy python-scipy
python-scipy:
Installed: 0.13.3-1build1
Candidate: 0.13.3-1build1
Version table:
*** 0.13.3-1build1 0
500 http://br.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
I tried the following solution and get the same error message
renan@renan-1215B:~$ /usr/local/bin/python -c "import numpy"
File "<string>", line 1, in <module>
I want to know if it would be too much painful to remove one of these pythons (I saw some warnings to not remove python, otherwise it could crash the system, then I would not dare to do this by myself) If not, how could I do it ? And backing to the main question, what else should I try to import NumPy (I did not showed more attempts because after I notice 2 pythons installed I assumed that it could be a cause of my fail attempts, but I can say that apt-get and aptitude did not work.)
/usr/local
is probably one installed from source, and could/should be removed. Did you install from source? Also, does/usr/bin/python -c 'import numpy'
work? – muru Jan 29 '15 at 02:56apt-get
would be the wrong command. Software installed viaapt-get
don't touch/usr/local
. Did you at any time, compile Python (something like./configure; make; sudo make install
)? – muru Jan 29 '15 at 05:12/usr/local/bin/python
, so runmake install
again to see which files where installed and delete them like the linked answer did. – muru Jan 29 '15 at 16:54
