My late 2019 iMac was running out of disk space and since all the upgrade kits seem to be out of stock (and the upgrade process difficult) I decided to try moving my home directory to an external thunderbolt SSD as per the instructions here https://www.lifewire.com/move-macs-home-folder-new-location-2260157
Whether a result of encryption (external SSD is encrypted APFS with the password stored in my users keychain), or a slow mount, I’m no longer able to login to my computer which simply states ‘unable to login an error has occurred’
I’ve tried using single user mode and disabling various security features to mount the drive to no avail which always results in ‘permission denied’ as per https://apple.stackexchange.com/a/388479
What I’ve been able to do is boot into recovery mode and mount the ‘Macintosh HD - Data’ drive through disk utility.
I can see my home directory is still on this internal drive and is writeable and think if I can just change the setting back manually I should be able to login.
Does anyone know where this setting is located so I can simply edit it through the command line?
(Example screenshot from Apple discussion)
Max OS Monterey 12.? 27” iMac 2019 FileVault enabled on local ssd APFS encryption on external thunderbolt SSD
dscl . -read Users/bb NFSHomeDirectory
should print the current value, and withdscl . -change Users/demouser NFSHomeDirectory oldValue /Users/bb
you might be able so reset it to the default. – Martin R Feb 23 '22 at 09:52dscl
tool. But to be honest, I do not know what exactly is possible in the single-user mode. Doesdscl . -list Users
show your account? What aboutdscl . -read Users/yourUserName
? – Martin R Feb 23 '22 at 10:05/var/db/.AppleSetupDone
file - I realize now the actual path is/Macintosh HD - Data/private/var/db/.AppleSetupDone
as per https://apple.stackexchange.com/questions/347816/no-such-file-when-running-rm-applesetupdone-from-single-user-mode. FYI - now that I am logged in again to the actual system,dscl . -list Users
does show the users so I think single user mode is indeed querying a different directory system. Thank you for the help. – waffl Feb 23 '22 at 10:35
