18
I've noticed a strange problem with my 2018 MacBook Pro. Sometimes, when I use it with the (original) adapter, it says that the power source is power adapter, but the battery is still draining and not charging:
This is a huge problem as the level of charge can become very low before I even notice it. Also, I'm not doing any resource-intensive work. As an experiment I left it running and observed the charge get down to 40% before I disconnect the cable and reconnect so the charging would start.
What may be causing this issue?
bmike
  • 235,889
  • If I recall correctly I had a similar case where the battery in the end was damaged. But that was on a much older MacBookAir... have you tried SMC reset, PRAM/NVRAM reset and different startup modes (especially safe mode)? – X_841 Mar 01 '20 at 17:55
  • I don't think it's a problem with the battery as the computer is pretty new. Also, hardware information shows no problem with it. Are there any drawbacks to resetting SMC/NVRAM? – Eugene Yarmash Mar 01 '20 at 18:33
  • @X_841 - What in the pre-boot environment (NVRAM, not PRAM. That was for PPC Macs) would be related to charging the battery? Also, what does Safe Mode have to do with charging? – Allan Mar 03 '20 at 04:06
  • Do you only see this message when the battery is charged to 93% or higher?If so, that's nothing to worry about. – benwiggy Mar 03 '20 at 07:33
    @benwiggy: As I mentioned, it could go to pretty low level of charge this way (say, 40%) before I notice the issue. Re-connecting the power adapter makes the battery start charging. – Eugene Yarmash Mar 06 '20 at 14:09
  • @EugeneYarmash Take it to an Apple Store or other Apple-qualified technician. – benwiggy Mar 06 '20 at 14:35
5 Answers5
There's three possibilities:
  • Battery Management is Enabled. Catalina introduced a feature called Battery Health Management where it will lower the maximum charge while in this mode. If connected to a charger, it may appear that the Mac isn't charging.
  • Defective battery. It happens. Even on new computers. Basically, the battery is not holding a charge meaning it discharges faster than it can be charged. In this case the battery needs to be replaced. There are some steps you can take to diagnose the battery.
  • Defective charger. The fact that you said "Sometimes when you use it with the original adapter..." points to an intermittent problem. Your charger may not be able to supply the needed current to both charge the battery and power your laptop. There's also the possibility that you're using the incorrect charger. For example, you may be using the 61 watt charger when the MacBook Pro requires the 87 watt charger.
The easiest thing to do is to try a different and correct charger for your MacBook Pro. If the problem persists even after you try a different charger, it's likely your battery and you'll need to take it in for service.
Allan
  • 101,432
  • Thank you, for me it was a charger issue. I have two chargers that look identical but one of them charges fine while the other apparently does not. Would be helpful if Apple gave a more descriptive diagnostic error about what the issue is, like "unable to charge from this charger; expects 100 W but only 10 W available" (totally making up the error reason, but you get the idea). – Nic Scozzaro Oct 11 '21 at 06:19
I found that I could get a port that was not working to start working by unplugging the cable at the power adapter (leaving it plugged in at the laptop) and then reconnecting it. It's not clear to me what this is doing or if it's placebo, but it's odd.
nohillside
  • 100,768
prblm2
  • 41
Although my experience is with an older MagSafe 2 model, this may work for later MacBooks as well:
  1. Look for debris / corrosion / gunk on both sides of the connection.
  2. Plug charger out and shut down laptop
  3. Clean both plug and socket terminals with toothpick / cotton swab immersed in pure alcohol or appropriate cleansing solution
  4. Wait some seconds for solution to evaporate and reconnect
I too had this problem and then I found this article on Apple website https://support.apple.com/en-in/guide/mac-help/mh20876/mac . Read the third point on the website, try turning off the Battery Health Management in Energy Saver Preference. The charging resumed immediately on my Macbook after I did that.
tonbck
Well, Apple care replaced the entire logic board but it did not fix the problem in my case. Later I discovered that is was faulty charging cable. Therefore, I suggest to check with alternate charging cable and charger first. This problem has nothing to do with macOS Catalina.
irsis
  • 111
