My MacBook Pro early 2011 developed the same problem many people have: it stopped starting up. Trying to follow the instructions in this post: GPU problem - Boot Hangs on Grey Screen and partly this: Single-User-Recovery-Mode on High Sierra 10.13.6, especially Luca Bonavita's suggestion, I got stuck when I tried to create the Extensions-off folder. My MBP has a partitioned hard drive. When I start up in single user mode, it addresses the "first" partition, which runs on Mountain Lion, so the Extensions-off folder was created on that partition. However, ML does not not have the offending AMDRadeonX3000.kext file, so I ended up with: No such file or directory when trying to move the kext. I tried to access the other partition that runs El Capitan via target mode with the below code, but could not even get past the first step.
cd /Volumes/Yosemite
(Yosemite being the partition that runs El Capitan)
mkdir -p /Yosemite/System/Library/Extensions-off
I assume the csrutil disable
command is necessary afterall? If so, how can I use that on the second partition? Or is it the /sbin/mount -uw /
that was missing? Or did I just make a mistake in the code (basically just copying and pasting, as the noobe that I am...)?
Edit: The code was wrong; it should've started with sudo
and then /Volumes
sudo mkdir -p /Volumes/Yosemite/System/Library/Extensions-off
The System integrity is OFF on the ML (first) partition. Edit: Apparently, ML does not have SIP, hence DiskUtility on the iMac showed OFF for that volume.
I followed the instructions for Sierra, because I was not able to boot into single user recovery mode.
csrutil status
Result should beSystem Integrity Protection status: disabled. [or enabled]
orcommand not found
It can only be toggled from a recovery partition that knows what it is. – Tetsujin Jan 31 '20 at 18:33sudo mkdir -p /Volumes/Yosemite/System/Library/Extensions-off
in a non-SIP system - your 2nd command is missing thesudo
part & it's the wrong path. – klanomath Jan 31 '20 at 19:03/Yosemite…
will work nowhere) – LаngLаngС Jan 31 '20 at 19:26sudo
is not required. – klanomath Jan 31 '20 at 19:30
