Is there any way (command/option) to power-off the device using adb command?
PHP Learner
  • 549
  • @AndrewT. This question does not solve my problem. I tried reboot -p--->Operation not permitted. Other commands returns not found. On the other hand, all of those commands are shell commands that are executed on the device, But I am looking for a command such as adb reboot -s or adb shutdown that is entered on PC command line. – PHP Learner Jan 30 '15 at 05:04
  • Still, it's a duplicate of that question. It's an unfortunate situation that you still can't comment on other post/put bounty, but since you've tried it, incorporate the info you wrote on comment to the question. I also tried it just now, and it also doesn't work. Somehow I suspect there is a change in adb.exe between SDK. – Andrew T. Jan 30 '15 at 05:42
  • Try "adb shell" and see if device has "shutdown" command (it should be under /system/bin/). If shutdown binary is there, then type "shutdown" command should work – AADAndroidEnthusiasts Jan 30 '15 at 17:40
