i have recently purchased Android Tv Box CS928 from Chinese site http://www.aliexpress.com/item/CS928-Android-4-4-kitkat-Rk3288-A17-quad-core-2GB-16GB-2-4-5-0Ghz-100M/1939723909.html
i bought this because it says
Network     2.4GHz/5GHz WiFi 802.11 b/g/n and 802.11 a/c. Support LAN 100M/1000M Base-T
so i was under impression that (802.11 n and 802.11 a/c means 300 Mbps) this will be perfect fit for my home wireless network which is working at 300 Mbps using wireless router TP-Link 1043ND
but when i connected my Android Tv Box CS928 to wireless network in my home i can only get 65 Mbps highest speed at the Android Tv Box CS928 , i even tried placing the my TP-Link router next to Android TV box but it didn't increase the Wireless speed , it shows signal strength as 100% but the wireless speed is 65 Mbps.
So i have tried forcing my TP-LINK wireless router to transmit and work at only at 300 Mbps speed by setting
Channel:    1
Mode:   11n only
Channel Width:  40MHz
Max Tx Rate:    300Mbps
but still the Android TV BOX connection status shows wireless speed as 65 Mbps
why is that ?
how can i increase the wireless transfer speed of Android TV box so i can watch HD movies streamed from my PC to Android TV Box?
