I need to install about 20 tablets powered 24/7 (24 hours, all week). Is there any problem or potencial damage about it?
whitenoisedb
  • 161
There should be nothing to stop you from doing so.
As long as you keep an eye on those tablets and make sure they are setup as they are supposed to they will work.
Small suggestion: Don't connect them 24/7 to the charger. The battery will wear out slower if you keep it's charge between 40-80%.
Android shouldn't be a problem for you.
GiantTree
  • 4,062
  • 26
  • Thanks. Yes, it would be ideal to keep its charge between 40-80%, however they are supposed to be connected permanately inside a commercial store. That's why I wonder what happens if battery is always at 100% charging, or if it is another solution to this. – whitenoisedb Jan 17 '15 at 01:32
