I am trying to transfer APKS from my Moto G to Android one through Buetooth (I have unknown sources enabled) but it is not being transferred. What do I do?
Asked
Active
Viewed 51 times
You can download ES File Explorer and change the file's extension to txt, like this:
So when the other device gets the file, you remove the ".txt" and it'll be an APK again.
David Zavalla
- 38
- 1
- 5
The easiest way around this is to download apk share ! You can create apk's for your apps and share them through different means ! Link to app : https://play.google.com/store/apps/details?id=com.kayan.nurav.apkshare&hl=en&referrer=utm_source%3Dgoogle%26utm_medium%3Dorganic%26utm_term%3Dapk+share&pcampaignid=APPU_8xc6VIiBA8e0uQSTiYJo
Terrorbladezz
- 1
- 1
