I'm playing around with the latest android-x86 (4.4) in virtualbox. The setup can connect to the external network only through a NAT ethernet device that is emulated by virtual box. This gets autoconfigured just fine and i can ping computers on my LAN.
If I export http_proxy=<host>:<port> in a terminal, I can wget web pages. However I am unable to set the proxy settings globally for all apps.
The proxy settings are displayed only after a wifi network is connected, and I lack any wifi devices in the virtual machine.
I have tried the following in the root terminal accesible from alt+f1:
setprop global_http_proxy_host <host>
setprop global_http_proxy_port <port>
setprop net.gprs.http-proxy http://<host>:<port>
But this fails to have any effect. Even new terminals lack the env variable for the proxy. These settings appear to be set when I check it by executing getprop
I found this link to the fragment that seems to display the proxys selector for the wifi.
Is there any way that I can manually set all the settings that are affected by this fragment?
eldarerathis
  • 36,787
  • 144
  • 175
staticd
  • 203
This solution worked for me.
Just enter the following command in a terminal (change PROXYIP:PROXYPORT )
iptables -t nat -A OUTPUT -o eth0 -p tcp --dport 80 -j DNAT --to PROXYIP:PROXYPORT
Source: https://groups.google.com/forum/#!topic/android-x86/XfIRyHQ5nmk
I had too tried all your commands without success. I was stuck behind a proxy trying to setup Android x86 with a VirtualBox VM which only had eth0. I was stuck at the activation screen not resolving the needed webpages to continue into the OS. After running the above command, I was able to reach the web and continue. Results may vary per proxy environment.
Edit: This didn't get me too far, but it got me somewhere. The same trick didn't work for 443.
Francesco
  • 192
Kynolin
  • 61
