I have Micromax canvas 2.2 a114. I am in strong network zone and use 2g internet all time and time without network is 0%. So why it is consuming more battery. I also never in weak signal.??
Asked
Active
Viewed 821 times
What matters is, what is your total battery life, if your phone lasts 2-3 days, then 30% is reasonable, however if it only lasts 8-10 hours, then it isn't.
If it is the latter I would recommend clearing your cache (and davlik cache if you can) and or performing a factory reset and seeing if the problem persists, also try using a different sim card on another network.
ollie299792458
- 676
- 4
- 15
It is is d for 7 hours.happened with all sim cards. – Ridham Aug 20 '14 at 15:22
I would try the steps I have suggested, also I would recommend testing your battery capacity with nova battery tester (it should be 2000mah) – ollie299792458 Aug 21 '14 at 08:43
