I have an android smart box with a built-in wifi and I want to add a dongle to the box so that I can monitor the network. I have found a similar question with somewhat vague answer(at least to me); Android as WiFi bridge with AP
I have 3 wifi dongles at the moment. The device can detect 2 of them(with dmesg run from shell and also a small android application which gets vendorId and productId of the connected usb devices) but I don't know if the required drivers are installed or modules are loaded.
My question is if the devices are detected, can i make use of them in an android app? or do I have to download android source code and compile it with new drivers/modules?
Basically I'm a little bit stuck and any pointers would be appreciated.
Thank you
saccu
  • What do you mean, "so that I can monitor the network"? I don't see what a second Wi-Fi network would help you do. – Dan Hulme Aug 13 '14 at 10:09
  • I mean I want to get info about the surrounding wifi devices like signal strength mac address etc.(with a dongle) and still be able to communicate with other devices over wifi(with the built-in wifi). I could give an example if it is still not clear. – saccu Aug 13 '14 at 10:18
  • OK, you should [edit] your question to add that information. Also, you should say what device you have, and what Wi-Fi dongles you're trying to use. Some Android devices support some Wi-Fi dongles; if you name the particular devices, you might get a more specific answer from someone who has the same. – Dan Hulme Aug 13 '14 at 13:34
  • Specific devices have nothing to do with my question. But if it led you to believe to i think the question may be a bit vague so i edited it a bit. – saccu Aug 15 '14 at 13:41
Why not use the built-in Wi-Fi, and use a network monitor tool like Fing?
geffchang
  • 17,565
  • 18
  • 57
  • 73
  • Built-in wifi will be used for communicating with other devices on the network while the dongle will look for other devices without being connected to a network so it can monitor every device in range. – saccu Aug 13 '14 at 12:36
