On iPhone I could set a maximum volume limit so I wouldnt be able to put my music too loud accidentally. How do I do this in Android? I dont seem to find the setting in the volume menu.
Asked
Active
Viewed 6,723 times
-1
"navigate to System -> etc -> mixer_paths.xml. Open the file in the text editor, then locate the text
. By default, the headphone volume level is set to max out at "84." Edit these values to whatever you want " as per http://oneplus.wonderhowto.com See if that's true for your device as well. Also, which Android device and version are you using? – Firelord Nov 16 '15 at 17:15
If you are referring to the headphone output rather than the speaker, then you could use an app such as "Headset Button Controller" Link to Play Store Trial.
I have the paid version on my phone, and I like it a lot. It allows you to set up button controls for various apps, but it also has a nice feature that allows you to set the default volume when you plug in the headset. You can set the minimum and maximum, also, but this would only work with a headset like the iphone's, with volume control that controls the phone.
Marty Fried
- 296
- 1
- 9
