I have 1 android device, 1 wired headphones, 1 wireless headphones, 2 ppl willing to watch film. When I connect both of headphones only wired work.
Is it possible to use both of headphones simultaneously?
i have tried and tried, never works, either use 2 wired earphones or use 2 wireless Bluetooth earphones
http://androidforums.com/threads/using-2-bluetooth-headsets-at-once.178052/
There are a few recommendations but this seems like it would work: Buy a Y splitter which will turn one 3.5mm headset jack into two Buy a Bluetooth Audio Transmitter like this one Plug your headphones into the one Y jack Plug your Transmitter into the other jack Enjoy headphones + bluetooth working simultaneously Theoretically, you could also connect 2 wired headsets or 2 bluetooth headsets with this method. This is more of a worst-case scenario hack. It seems devices with Bluetooth 4.0+ are already able to support multiple profiles:
Use the adapter that allow to connect wired headset. The smartphone switchs automatically to the wired headphone if inserted.
