14
I often hear the recommendation that fixing your device to 2G saves a lot of juice compared to using 3G.
Is that true? Or is it really a myth?
Matt
  • 258
Izzy
  • 91,166
  • 73
  • 343
  • 943
Fast answer:
Nes. Yo. Well, it all depends... on how you use your device.
Detailed answer
Self-Experiment
I just did a self-experiment to find out. Until now, I had all my devices fixed to 2G -- as that should "save juice", like the question suggests. So for 4 days now, I have 3G enabled. Surprisingly: No difference which could not be explained by measurement errors or slightly different situations (after all, I had a. no lab conditions and b. just tested with a single device). Humm. Time to go for some facts, and do some calculations.
Hard data
I already posted some hard data on battery consumptions of components as answer to the question What can I do to increase battery life on my Android device?, more than half a year ago. So now I picked the relevant values, made an average over the two devices, and -- I admit -- slightly adjusted things to reduce differences:
  1. I took the best GSM (2G) speed possible to make 2G seem faster
  2. I took worse conditions to "slow down" UMTS (3G) to conditions which should be met even in areas where it was not improved to the "the latest cutting-edge" (oh, speaking of "edge": 2G assumes EDGE here).
And now I've got some surprising answers: Whether 2G saves more juice than 3G, or vice versa, depends on how you use your device. I created 4 different "usage-groups", and added a 5th special case at the end. Here are my results:
Few phone minutes, few data
Yeah -- that's me: 150..300 minutes talk per month, that makes not more than an average of 5..10 min per day. I have a 50 MB data flat, and hardly ever use it up (which makes for ~ 1.5 MB/day). So I'm mostly left with "standby":
  • ~UMTS StdBy 15 mW
  • ~GSM StdBy 10 mW
Consider that your screen uses 400..800 mW on average when turned on, a difference of 5 mW can safely be ignored. Besides, the little data even compensate -- but I get ahead of myself.
The 24/7 caller with no time for data
...better switches to 2G:
  • ~UMTS Tel 800 mW
  • ~GSM Tel 400 mW
As you can see, when on-call, 3G uses about twice as much juice than 2G would use (and you don't speak faster on 3G -- a call is a call, and will take the same time). So if you spend a lot of time in calls, and have only little data traffic, you're much better off with 2G/GSM.
Few phone minutes, but big data sucker
Here comes the big surprise: This group saves a lot when sticking with 3G/UMTS:
  • ~UMTS XFER 1200 mW
  • ~EDGE XFER 1000 mW
Doesn't look like a huge difference? OK: looking on "how much does it suck per minute" might not make the big deal. So we need a second component:
  • ~UMTS speed dl/ul 7/1 MBit/s (HSDPA/HSUPA)
  • ~EDGE speed dl/ul 200/100 kbit/s
You see I assumed max speed for EDGE, but not the state-of-the-art (20 MBit/s downstream) for UMTS. UMTS coverage might differ between areas, but the 7+ MBit/s should be available everywhere. Now let's look how long the download/upload of 1 MB data takes, and how much juice that corresponds to:
  • ~UMTS 1MB dl/ul 1s/8s ~ 1200/9600 mWs
  • ~EDGE 1MB dl/ul 40s/80s ~ 40.000/80.000 mWs
That's about a factor of 1:7 for upload, and even more than 1:30 for download!
So yeah: This group is definitely better off sticking to 3G!!!
Multi-Tasker: 24/7 on call while using full data
This now very much depends on what "full data" stands for, and if you're really a 24/7 on-call-boy (or girl). No clear answer for this, you must put your own data into the equation and do the calculation. It's rather 50:50 -- as with group #1, you might run a "zero growth" -- or tend to either group 2 or group 3.
Special case: The "hopper"
Especially in rural areas, coverage might be, humm, "slippery". Your device might be permanently toggling between 2G and 3G, always on the hunt for the better signal. Here all the above might become relative, as the toggling itself is drinking the juice. If you are in such a situation: Check to which of the 4 groups above you fit best, and fix your device to either 3G or 2G, depending on.
Btw: A similar situation would be if you've got the idea to toggle between 2G/3G whenever you switch your display off/on. As the toggling requires up to 10s full-power (to find the corresponding stations; 2G and 3G use different frequencies), you wouldn't really "save juice".
Epilog
Yepp, I completely forgot about 4G/LTE. But incidentally. First: I have no 4G/LTE device for a self-experiment. Second: I have no "hard data" on 4G/LTE. So all I could do is guessing. Doing that, OK, OK: It most likely will be the same as above -- just increment the numbers by one :)
Izzy
  • 91,166
  • 73
  • 343
  • 943
    Note: the "hopper" scenario also applies if you travel by underground - most cities have station coverage, but not in tunnels, inducing the power-intensive signal search many times in the space of a few minutes. In such cases, disabling mobile data altogether while travelling by underground has dramatically improved battery life on my devices. – Piskvor left the building May 24 '13 at 11:08
  • Since this question just resurfaced it might be nice to get an update of your data to include 4G now that it's been a while. – Thomas Martin May 08 '15 at 10:37
  • Might be, @ThomasMartin – but I cannot do that. I'm not using 4G, and I have no stats to base an update on. You could ask a new question especially for 4G, and link to this one here as reference. – Izzy May 08 '15 at 10:45
For me switching to 2G has helped my battery last 2-3 hours longer. I use a samsung galaxy s3 I9300. Was using 3G connection for the first two months and the battery would be over by 14-15 hours under normal-heavy usage. Switched to 2G data couple of months back and the battery life has improved by 2-3 hours.
My usage has always been the same with both 3G and 2G. I use about 1.5GB of data every month. switching to 2G gave me better battery life for the same usage.
But while travelling , when there is fluctuations in network coverage , even 2G network mode drains battery. The network coverage has direct impact on the battery life. The better the network coverage , the better the battery life.
Screen , data transfer and games are the biggest battery hoggers for me. I have used some battery saving applications before but never found it to be useful, though other users may differ, its my opinion.
munna
  • Do you use a lot of data? How is 3g coverage in your area? Without any background, this does not say much. The question was not intended as a poll ;) – Izzy May 21 '13 at 06:55
  • My Data is ON 75% of the time. Mostly email and whatsApp. There are couple of places where 3G is absent. – munna May 21 '13 at 08:01
  • It's not whether your data is "turned on", but the amount of data transferred which makes the difference. Mail & Whatsapp usually don't use "big data". What's your monthly used volume on mobile data? That's what counts here, provided signal strength is comparable for 2g/3g. See my answer for details: huge volume => 3g is better, low volume => 2g is to be prefered. – Izzy May 21 '13 at 11:27
  • i was just giving an opinion according to my experience. My usage has always been the same with both 3G and 2G. I use about 1.5GB of data every month. switching to 2G gave me better battery life for the same usage. – munna May 21 '13 at 13:27
  • OK, thanks! With those details it becomes more helpful :) Maybe you could update your answer to include them (2g/3g coverage plus the average data usage per month)? Thanks in advance :) – Izzy May 21 '13 at 13:40
  • I live in a city and the coverage for both 2G and 3G is excellent. I make/receive phone calls for about 20-30 minutes a day. Use approximately 1.5gb of data every month.
    – munna May 22 '13 at 06:43
  • munna, I meant you should edit your answer to include those details :) Many users don't go through all of the comments, so it's always best to include additional details with the answer itself. – Izzy May 22 '13 at 06:46
I agree that the network coverage has direct impact on the battery life. If you have a good 4G coverage, your battery will last longer than if you use 2G but with bad coverage.
Anyway, the white paper of Xperia V for example gives more battery if your smartphone uses 3G than in 2G mode. The same with other Xperia smartphones. Is it a mystery or is it a mistake?
geffchang
  • 17,565
  • 18
  • 57
  • 73
one
Specs of Xperia SP according to Sony.
Talk time (max.):
2G: 625 min. (10.4 h)
3G: 1133 min. (18.9 h)
Stand-by (max.):
2G: 635 h (26.5 days)
3G: 734 h (30.6 days)
4G: 709 h (29.5 days)
Chico
  • Chico, we don't collect device specs here. And just listing the theoretical talk time the manufacturer put on the pocket doesn't answer the question (unless you talk non-stop and do nothing else with the device). Apart from that, OP has no Sony device. – Izzy Feb 16 '17 at 07:39
