12
The first recommended step in the installation of CyanogenMod on Samsung Galaxy S is flashing a custom recovery like ClockworkMod or the one from Replicant with a command like:
heimdall flash --kernel path/to/recovery.img
Now I feel that the instructions might be misleading:
I have done the first step wanting just to have a custom recovery mode, without proceeding to replacing the main OS on the device.
It seems I have done that wrong, because the device now always boots into the recovery mode.
What would be the correct heimdall command to just install a custom recovery system without touching the main system?
  • It worked for me. But AFAIK it depends on the version of the stock ROM you have: Some custom recoveries are able to boot it, others not. I guess there is no general way. – Flow Apr 22 '13 at 07:51
  • @Flow So, the recovery mode and the normal mode are supposed to use the same image when booting? I was thinking that perhaps there are two different images for the different boot modes, and I replaced the wrong one by mistake, and that's the source of my problem: booting always into the recovery system (no matter whether other keys are pressed when powering up) after I executed the flashing command from the post, although I would really like to boot the old main system. – imz -- Ivan Zakharyaschev Apr 22 '13 at 08:18
  • No, if the custom kernel/recovery boots always into recovery then it's usually a sign that it is unable to find/boot the normal system. – Flow Apr 22 '13 at 08:24
  • He just needed to rerun print-pit cmd, then flash his boot.img into the partition where he'd flashed recovery.img, no? In my experience, they are almost always right next to each other. – Nate T May 30 '21 at 21:02
It depends on your PIT partition file.
Before you do anything using heimdall, print the partition table of your phone.
sudo heimdall print-pit
The output of the file is the location assigned to each partition. For example on my Galaxy S3, I have something like this:
--- Entry #20 ---
Binary Type: 0 (AP)
Device Type: 2 (MMC)
Identifier: 19
Attributes: 5 (Read/Write)
Update Attributes: 1 (FOTA)
Partition Block Size/Offset: 491520
Partition Block Count: 32768
File Offset (Obsolete): 0
File Size (Obsolete): 0
Partition Name: Kernel2
Flash Filename: recovery.img
FOTA Filename:
Now this tells me 3 main things:
  • Name the flash file: recovery.img
  • Location of the identifier 19
  • And finally the name of the recovery partition Kernel2
What does this means?
This means if I want to flash a recovery image I should use either the identifier 19, or the name Kernel2.
sudo heimdall flash --19 any-type-of-recovery.img
or
sudo heimdall flash --Kernel2 any-type-of-recovery.img
Bottom Line: Look at the pit file to figure out where to flash your recovery.
Cheers, Mel
lemel
  • 161
  • Just a note for others, if the recovery.img flash is successful but you let your device reboot as normal straight after, the boot image will likely remove the custom recovery image. Either use adb or use the recovery mode key combination as soon as heimdall is successful. – myol Jan 06 '22 at 07:00
One effective way with Heimdall is to just run
sudo heimdall flash --RECOVERY twrp.img
Worked for me on an S3 AT&T
Then when phone reboots, go into recovery via
adb reboot recovery
KhoPhi
  • 614
  • 18
    I also used --no-reboot flag. Otherwise the system booted and later on an official recovery seemed to be reinstalled so I couldn't enter TWRP. And thank You by the way. – kcpr May 16 '22 at 11:08
I do not know the partition mapping of the SGS, so my only suggestion would be to use the GUI (heimdall-frontend) and select the recovery partition only. As of restoration of the original system, my suggestion is to reflash the original ROM without touching /data. But backup it first using an advanced custom recovery like this one if possible: http://forum.xda-developers.com/showthread.php?t=2201860 (the key feature is custom backup/restore)
  • But what if I destroy the original OS when flashing the custom recovery? In my case, I flashed a custom recovery, but the OS doesn't boot after that... swhat could go wrong? That is something I didn't expect: I just wantee to flash a custom recovery, but do not install a new main OS. Now I'm forced to do that. – imz -- Ivan Zakharyaschev Aug 02 '13 at 17:45
heimdall flash --Recovery /Path/recovery.img --Kernel /Path/recovery.img
Replicant OS Recovery install
Firelord
  • 25,084
  • 124
  • 286
