51
Sometimes my SD card gets "corrupted" and this leads to many read/write errors. Usually, connecting the SD card to the windows 7 and selecting the "Error Checking" (Right click the drive > Tools > Error Checking) option finds the corruption and fixes it.
How do I check SD cards for drive errors and fix the same from within the android itself?
I'd also like to mention that I'm on rooted froyo with busybox installed.
Firelord
  • 25,084
  • 124
  • 286
Irfan
  • 2,921
  • 32
  • 48
    If you repeatedly have errors on your SD card, you should make sure that it is really of the stated capacity using H2testw (link only in German, software in German and English. I believe this is the official home despite appearances to the contrary). Bad SD cards will automatically corrupt. – Codebling Jul 08 '15 at 04:46
5 Answers5
18
You can fix this with the help of root and a terminal emulator (e.g. Android Terminal Emulator (or, alternatively, using adb shell). The binary to do the job is called fsck, and usually located in either /system/xbin or /system/bin. Sometimes you need a special variant of it, which might e.g. be called fsck.exfat or the like. So first let's make sure we find the right binary:
cd /system/xbin
ls fsc*
If not found, repeat with /system/bin. I will assume here it was found in the first place, and is simply called fsck (adjust the following correspondingly if that's not the case).
As fsck comes from the "Linux core", we can consult its man page for the syntax. Though there might be some options not working on Android, the most basic ones should. See the linked man page for details (or run a Linux VM and use man fsck in case that page disappears) -- I will stick to the basics here:
First we need to find the device your SD card is bound to. If it's mounted, the mount command will assist us:
mount
That's it, basically: Check the output and see where your SD card sits. Usually this is something using vold, but it's different between devices. Output may include something like /dev/block/vold/179:17 on /mnt/storage/sdcard -- in that case, the first part of my quote is our device. In order to repair the "drive", you need to unmount it first. This can be done via the settings menu, or, as we're just in the terminal, by issuing
umount /dev/block/vold/179:17
Now we can go for the repair job. Basic syntax is:
fsck [options] [-t fstype] <filesystem> [fsoptions]
So we first try the simplest approach and hope fsck figures out everything itself:
fsck -C -r /dev/block/vold/179:17
Which basically means: Show progress (-C), and always ask the user to repair (-r) any errors on /dev/block/vold/179:17. If this does not work out, check with the linked man page for further options.
Izzy
  • 91,166
  • 73
  • 343
  • 943
    You can also save yourself the cd steps if you want by using ls /system/bin/fsc* and ls /system/xbin/fsc* from whatever your current working directory is. You could even combine the two into one command with ls /system/xbin/fsc* /system/bin/fsc*. – eldarerathis Jan 31 '13 at 16:52
  • on some systems the command may also be named e2fsck, such as on my stock Australian Galaxy Nexus. – Lie Ryan Nov 09 '13 at 11:14
  • @LieRyan Sure you don't confuse things? e2fsck is the file system checker for extFS. So if it has a different name, it's rather fsck.fat or fsck_msdos (the latter a real world example from an old 2.2 ROM off my Moto). – Izzy Nov 09 '13 at 12:48
    No, I don't confuse things, what I wasn't aware of is that this question is actually about SD card. So yeah, I actually did confuse some things. Well strictly speaking, you can format your SD card as ext as well, so that might apply to people that does that. – Lie Ryan Nov 09 '13 at 12:57
    Point taken. Though the "average user" (or the one "in doubt") might better stick with FAT, at least for interoperability. At least until ExtFS is supported on the majority of OSs easily and by default without additional drivers required (guess Windows is and will remain a pitfall here, as usual). – Izzy Nov 09 '13 at 13:08
  • I only got unknown option -- C but tried running it with just fsck.exfat /dev/block/vold/179:9. Worked like a charm! – sturlabragason Mar 12 '14 at 22:27
    Thanks for this answer, I think it is what I need. I got an error on the umount, do you have to be root? – Organic Marble Dec 26 '16 at 13:35
    @OrganicMarble yes, of course – for all the above commands, or you don't get access to devices (everything starting with /dev) that way. – Izzy Dec 27 '16 at 20:50
  • Thanks! I was confused about root on the PC vs on the tablet.(I tried to do adb shell su). This answer and the one about fsck_msdos helped me fix my tablet. – Organic Marble Dec 28 '16 at 01:10
While other answers are correct (at least partially), just to add some extra notes. On recent Android releases you don't need to run filesystem check manually as vold handles this automatically. See When should I run a consistency check on my removable MicroSD card?
If you want to do this manually, you need a rooted device because it's not possible to access block devices on un-rooted devices. Also you need to un-mount the filesystem before checking for errors. Since Android 6 external SD card is mounted at /mnt/media_rw/[UUID] and then emulated on /mnt/runtime/[VIEW]/[UUID]. A VIEW is then bind-mounted to /storage/[UUID]. See details in How to save files to external SD card?.
After un-mounting SD card fully, run respective fsck.* binary on the block device. Usually init enumerates SD card block device as /dev/block/mmcblk1p* (p* denotes partition number, usually it's only 1) while vold creates another device node in /dev/block/vold/[MAJOR:MINOR]. You need to find the correct block device (may also check by mount | grep /mnt/media_rw before un-mounting filesystem).
For FAT[N] family of filesystems you can use fsck_msdos (or fsck.fat), and fsck.exfat for exFAT. If these aren't built with your ROM (exFAT was closed source until recently, so there could be license issues), you can use external binaries. Or build from (dosfstools or exfat) source code.
To run filesystem check:
~# fsck.exfat /dev/block/mmcblk1p1
Irfan Latif
  • 20,353
  • 70
  • 213
thank for this, it saves my day :)
root@android:/ # mount | grep -i sdcard
/dev/block/nandk /mnt/sdcard vfat rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
root@android:/ # /system/bin/fsck_msdos -y /dev/block/nandk
Dan Hulme
  • 35,000
  • 90
  • 155
junior
  • 39
I've found an app called AParted on the market that can "repair some damaged sdcard and scan for bad blocks" etc.
Andrew T.
  • 15,988
  • 74
  • 123
Irfan
  • 2,921
  • 32
  • 48
If I'm not mistaken you can force Android to fsck both the internal and external storage on reboot by doing the following depending on your ROM.
run terminal app and type
su
touch /forcefsck
Then reboot.
If your phone is not rooted, this will definitely fail.
Source: XDA Forums - [Q]How to fsck /data or /system?
Andrew T.
  • 15,988
  • 74
  • 123
Trekeyus
  • 64
  • What do you mean by "depending on your ROM"? – unforgettableidSupportsMonica Nov 27 '15 at 16:37
    That trick might not work on all phones. different phones may fail to do anything. Also your phone needs to be rooted. – Trekeyus Nov 28 '15 at 17:59
  • Once I've rebooted, how can I know whether or not fsck actually ran or not? – unforgettableidSupportsMonica Dec 14 '15 at 08:12
  • I'm not sure is andoid has a /var/log/fsck you can check but you can guess that it is workign if the bootup takes a little longer then normal – Trekeyus Dec 15 '15 at 15:19
    -1. I have downvoted your post. Here's why: I've spent more time looking into the matter. Your suggested technique is probably 100% mistaken. It may deceive readers into thinking that it helps, but the technique actually does nothing. – unforgettableidSupportsMonica Jun 03 '16 at 15:00
    touch /forcefsck will only work on a device with an init script which checks for the presence of a /forcefsck file. I don't know of one single Android device which has such an init script. So, although your technique will likely work on Debian, Ubuntu, and Mint devices, I highly doubt that it will work on any Android device. If anyone ever finds even one single Android device with an init script which checks for /forcefsck, please let me know! Simply reply to this comment. – unforgettableidSupportsMonica Jun 03 '16 at 15:00
