I have an Xperia S running 4.0.4. I often need to switch to a proxy for accessing a test server. I can do this fine by modifying my Wifi connection, selecting to show advanced options and then entering the proxy information manually.
The problem is that if I then need to disable the proxy, ICS 'forgets' the settings so I have to enter them manually each time. I need the proxy to work with Adobe Edge Inspect and so browser-specific proxy options are not the answer.
Is there a reputable third-party app which will let me switch between proxies for the current network connection?
yrajabi
  • 2,162
  • 18
  • 23
codecowboy
  • 191
Just try ProxyDroid
This app need root permission and IPTABLES support.
It's a full feature proxy application including support for HTTP/Socks proxy types, global/individual proxy mode, multiple profiles.
Binding configuration to WIFI's ssid or mobile connection is also supported.
There is an app which is perfect for your situation
Wifi Manager
You can also try Proxy Server Pro
Note: These apps do not ask for root permissions. But if you're supposed to have root permission, which you don't in your stock ROM, you may want to unlock the bootloader to have root access. See this for rooting details.
Sid
  • 4,176
  • 35
  • 60
