Possible Duplicate:
Does Froyo fix Samsung Galaxy S I9000's GPS problem?
the GPS on Samsung Galaxy S is said to be somewhat broken. Is this true even when using assisted GPS?
Possible Duplicate:
Disclaimer: I don't have any problems with GPS on my Galaxy, but I do get a lock a few seconds quicker if I have the aGPS functions switched on. It also means that I get a "rough" lock while I'm waiting (this rough lock is the one with the big blue circle, which is about half a mile wide when I'm in my home town, or about 30m wide in London.
(On Froyo at least) the settings to turn this on and off are in Settings, Location and Security, then you can use both "Use wireless networks Location determined by Wi-Fi and/or mobile networks" and "Use sensor aiding Enhance positioning and save power using sensors" to switch the aGPS on or off
Guides to fix the GPS issues with Captivate and Vibrant have just been posted.
http://androidcommunity.com/samsung-posts-gps-fix-guide-for-captivate-and-vibrant-20101130/
Do you have a Galaxy S with a broken GPS? what do you mean by broken? My Galaxy S (2.1) GPS took forever to find my location without "Use wireless networks" as described by GAThrawn, but once I enable it I almost have no problems finding my location quickly
