Possible Duplicate:
SD card partitioning? why? how?
I am trying to partition my sd card on my Samsung Galaxy Ace because I want to extend my memory using the app link2sd but I have some problems doing it.
I am following this procedure which I first tried on my HTC Desire with perfect results:
open gparted
search for the filesystem I am interested in
make a first fat32 partition of 3GB for the SD
make a second ext3 partition of 800MB to extend internal memory and use link2sd
apply
At this point I get an error, gparted is unable to do the first partition. If I try to change the orders/types of partition the error is always the same. Now I have a not allocated SD which is working to host data but I'd like it to work as an extension of my internal memory.
What I'm doing wrong? How can I solve it?
Thanks
cfdisk
andmkfs
directly. But following the steps of the gparted manual precisely, you should also be able to partition and format your card? Maybe you try in two steps: Start gparted, create the partitions, write your changes, exit gparted. Start gparted again, format your partitions, done. Step-by-Step in gparted manual should also do. – Izzy Sep 16 '12 at 22:57
