I just bought an Alcatel One Touch 995 with Gingerbread 2.3, when I display the notification the notification pane I have some icons I can click to activate GPS, wifi, bluetooth, rotation... I know there are some power control tools but I'd like to know if there is a way to cutomize the icons already displayed in my notification pane?
Romain
  • 51
Not by default. Certain ROMs like CyanogenMod do allow you to customise the toggles and the order in which they're displayed.
A possible workaround could be this app - Notification Toggle
Sparx
  • 10,882
  • 32
  • 43
Stock ROMs often don't allow to customize notification toggles. Either you'll have to flash a custom ROM (e.g. CyanogenMod) or install a third-party app (e.g. Widgetsoid).
iOS
  • 12,381
  • 63
  • 103
Not on a stock rom, sorry.
On certain custom/aftermarket ROM's, such as CyanogenMod, have the ability to customize these icons, by letting you add, remove and reorder the icons.
Liam W
  • 8,436
  • 40
  • 67
