So I formatted my phone today. I have not used it, and it was at 100% this morning. No apps installed, the screen was only on for about 10 minutes. Yet when I go to check it now, about 12 hours later, its battery is at 13%. I got a new battery a few days ago, so the battery isn't worn out. My phone is a myTouch 4G from t-mobile. My android version on it is 2.3.4
Izzy
  • 91,166
  • 73
  • 343
  • 943
Jon
  • 579
  • 25
    Please check if one of the following is helpful for you: http://android.stackexchange.com/questions/3052/what-does-battery-use-tell-and-how-is-it-implemented / http://android.stackexchange.com/questions/12347/what-can-cause-android-os-process-to-use-high-percentage-of-battery / http://android.stackexchange.com/questions/24675/battery-usage-by-certain-applications / http://android.stackexchange.com/questions/17382/how-can-i-find-out-what-causes-android-os-to-consume-battery – Izzy Aug 17 '12 at 20:55
You can install BetterBatteryStats (from Play Store or from XDA, the latter is free) and see which is causing this.
If you're running the phone without a SIM card this might also be the reason:
Some phones aren't tested well if there's no SIM inserted (my old Xperia X8 is such a phone for example).
Narrow it down this way:
  • Switch the phone to airplane mode (switches wifi/bluetooth/gsm off)
  • Then re-enable wifi (plus maybe bluetooth) again. Just leave it for a while and see if it's better now.
ce4
  • 14,446
  • 60
  • 106
