After installing android-tools-adb and android-tools-fastboot from a ppa and adding:
SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", MODE="0666", GROUP="plugdev", SYMLINK+="android%n"
to /etc/udev/rules.d/51-android.rules (plus chmod a+r ...), and 0x18d1 to ~/.android/adb_usb.ini, after issuing:
$ sudo udevadm control --reload-rules
$ sudo service udev restart
$ sudo udevadm trigger
adb devices still refuses to see anything (with or without sudo). It doesn't matter if I start with VolUp in Recovery mode, or not, nothing happens (restarts included). The problem is, somewhere along the road I performed a factory reset, so now I'm stuck on the FRP screen (papers, along with the darn PIN, not available anymore). Since lsusb has no problems, I have to deduce that the cable is not the problem. However, fastboot seems to work (if I get into the menu), but I can't do anything with it.
Unfortunately, USB debugging was not enabled prior to this, and from what I read there is a way to enable it, but that implies adb seeing my phone (as if with a "broken screen"). OTOH, by and large I see that USB debugging must be enabled in order for adb to work. That's very confusing.
I'm out of ideas. Is there anything else that can be done? Contacting seller & co are out of the question -- this was a gift, long time ago, moved out.
  • AFAIK you can't run adbwithout enabling user debugging Even if you could you are stuck with FRP not allowing you to log into your device – beeshyams Dec 23 '23 at 00:17
  • @beeshyams One of the several answers I found was this. There were several others in the same line but, it's also true that the majority of the answers seemed to agree with you. However, you can see the confusion. Because if it is possible then flashing should be possible from the recovery menu (don't care about the FRP). But, if I knew... Also, in that answer it says to mount data but that no longer exists due to factory reset, I think (bummer). – a concerned citizen Dec 23 '23 at 08:35
  • @aconcernedcitizen The mentioned adb commands in those answers are to be used with a custom recovery ROM with adb support. Such a custom ROM requires an bootloader unlocked device. – Robert Dec 23 '23 at 12:59
  • @beeshyams In the meantime I found this but, even if I can't find the RSA Certificate, as the post in there mentions, it seems incomplete: why go through the trouble of modifying the SU Update thing if nothing happens with it? And if it does, what? Because in the recovery menu, if I issue Apply update from ADB, adb can see the phone as "sideload". So, some hopes? – a concerned citizen Dec 23 '23 at 17:02
