I want to root my device and then modify files on the system partition.
I want to enable multi user support and install busy box. But there are many other reasons why someone would want to do this.
My question is if this can disturb system updates (not app updates)?
Will a system update simply overwrite the old system image? (Reverting all my changes).
Or will the update fail?
To answer my question it would be good to know how an Android system update works. (File based/image based. Is it delta?)
