This seems like a fairly basic thing but I'm having trouble nonetheless. I'd like my calls to ring (with sound) while messages vibrate (no sound). How do I do this?
  • Setting sound mode to "sound" and turning notification volume down means calls ring, but I get no vibration.
  • Setting sound mode to "vibrate" means messages vibrate, but I get no ringing for calls.
I am using Android 11 and have a Samsung Glaxy A71.
Rohit Gupta
  • 1,795
  • 24
user2260199
  • 121
  • Grant Messages app the VIBRATE permission while disallow to the Phone app: https://android.stackexchange.com/a/215658/218526. Or replace the stock Phone app with some other app which provides control over vibration behavior. – Irfan Latif Dec 20 '21 at 10:50
There is a very simple solution
  1. The Ringtones (used by Calls) and Notification sounds (used by Messages) can be set to different audio.
  2. For Notifications (under Settings->Sounds and Vibration), select a tone without audio.
As an example Zedge has such ringtones.
Rohit Gupta
  • 1,795
  • 24
