I have a Samsung Galaxy S7 and tried installing the custom ROM LineageOS because what could go wrong?
Anyways I followed this guide which makes you install TWRP 3.4.0-0 under the Installing a custom recovery using heimdall section.
I did that and I can (successfully?) boot into TWRP. However when tapping Reboot -> System or trying to boot into my standard android system I am stuck in a boot loop where The Samsung logo reappears every 5 seconds or so.
Here is what I've tried:
  • The command dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/fota from here
  • The command dd if=/dev/zero of=/dev/block/bootdevice/by-name/misc bs=256 count=1 conv=notrunc from here
  • Wiping my entire phone from TWRP
None of those things made any difference.
I really just hope that I didn't brick my phone.
EVARATE
  • https://android.stackexchange.com/q/214902 https://android.stackexchange.com/q/225021 if i understand your question you didn't install lineageos but want to boot stock ROM? that will fail for various reasons. continue installing lineageos and format userdata partition – alecxs Sep 11 '20 at 09:44
