I just got Inland USB-A 5,200mAh Power Bank w/ LED Indicators for my android phone. It has a one-year warrantee, which seems to tell that its battery might degrade significantly after one year of uses.
The power bank came fully charged. I don't have a plan of using it sometime soon, except for something unexpectedly, and will just set it aside for weeks or even months. I was wondering how to slow down battery degradation as much as possible?
For example:
  • In what percentage of charge shall I leave it, when I set it aside? Emptily, fully charged, or somewhere between?
  • Does its battery degradation depend on how many times it has been discharged and then charged, and how often it has been ?
beeshyams
  • 40,739
  • 30
  • 119
  • 269
Tim
  • 485
Power banks too have the same type of batteries as Android devices (Li-Ion or Li-Po) so the answers covering points you raised are :
40% is the best for storage
Quoting from this answer
When the phone is marketed, manufacturers, typically charge the battery to around 40% as you may have noticed. This is good for battery longevity and ensures battery degradation does not occur on storage. See BU-702: How to Store Batteries for better understanding
Yes. The more you use the battery , more the number of discharge cycles ( which covers both charging and discharging as explained earlier) and drop in battery capacity... (see answer for graphs and picture)
Now, the unasked part, charging while in use, see this answer
charge when the battery drops to 50% and stop charging at 80 or 90%.
You may want to look at hardware solution for the last point.
beeshyams
  • 40,739
  • 30
  • 119
  • 269
