Please read the full text and help me if anything can solve my problem. Also I can't go to Mi help center due to this lockdown, so can you suggest ways the help center person would do to fix this issue?
I have Redmi Note 4 (SD). I flashed MIUI 11.0.6.0 port for mido (ROM discussed in this video.) It had many bugs so I was trying to flash back to stock ROM using Mi Flash Tool (old version).
I was using linux for fastboot and adb commands and for Mi Flash Tool i was using win 7 in virtual box
I selected clean_all&lock.bat But after systerm image processing it gave me error
error message said something about partition not been empty(sorry cant remember the exact error and log file also doesn't exist anymore)
Now my phone was on fastboot mode for atleast 5 hours so I used
fastboot reboot
via linux terminal.
But phone didn't boot and gave me black (empty screen)
I thought might be battery is low but when I connected it to charger nothing happened.
I couldn't boot to recovery or fastboot mode (and can't do it now too).
I searched on internet more for help and found about EDL mode. I tried that but Virtual Machine wasn't loading the Qualcomm driver so I installed windows 10 .
ALSO I searched about the error on internet and found the solution to use latest mi flash tool.
So I tried with that. BUT I AM NOT SURE IF IT IS CONNECTED BY PROPER EDL MODE BECAUSE MI FLASH TOOL INSTEAD OF SHOWING COMX AS DEVICE NAME, IT IS SHOWING MY INCOMPLETE FASTBOOT DEVICE NAME .
I clicked to flash by selecting clean all&lock but it gave me this error
The volume does not contain a recognized file system.Please make sure that all required file system drivers are loaded and that the volume is not corrupted.
ALSO THE DEVICE IS SHOWN IN LATEST VERSION BUT NOT IN OLDER VERSION IN EDL MODE
Then after many attempts to flash
Now it shows this
$fastboot -s 34564c88 getvar product 2>&1 | findstr /r /c:"^product: *MSM8953" || fastboot -s 34564c88 getvar product 2>&1 | findstr /r /c:"^product: *mido" || echo Missmatching image and device
It was stuck at this for like 1000+ seconds.
I searched about it and tried this solution. In this it tell to delete line 10 and 11 but in mine file it was present at 4 places so i deleted them all.
But then it got stuck at next command in clean_all&lock.bat file
[9:39:38 PM 34564c88]:start process id 8956 name cmd [9:39:38 PM 34564c88]:info1:$rem fastboot -s 34564c88 erase bk12 2>&1 [9:39:38 PM 34564c88]:info1:$if not 0 == 0 exit /B 1 [9:39:38 PM 34564c88]:info1:$fastboot -s 34564c88 oem device-info 2>&1 | findstr /r /c:"Device unlocked: true" || echo Device oem locked
To give a try I deleted this line too but then it got stuck at next line.
ALSO TO ACCESS EDL WE NEED TO SHORT JTAG PINS BUT MY LAPTOP (WITH WIN 10) ACCEPTS IT WITHOUT DOING THAT
Izzy
  • 91,166
  • 73
  • 343
  • 943
Pragyan
  • 161
  • @alecxs I tried qfli tool and it gave me this error Download Fail:Switch To EDL FailUnable to load DLL 'QMSL_MSVC10R.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E) – Pragyan May 04 '20 at 18:05
  • where have you posted the link because using this qualcomm i tried qfli tool and it gave me this error Download Fail:Switch To EDL FailUnable to load DLL 'QMSL_MSVC10R.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E). I am unable to boot to edl mode (i think!) – Pragyan May 04 '20 at 18:17
  • look at page 3 there you will find test point. after you managed this, there is a nice answer with link to pure Linux Qualcomm USB flashing tool – alecxs May 04 '20 at 18:18
  • i just switched from linux for just my phone to work. Can I run it in kali linux live usb or any other bootable usb for linux distro with persistence because virtual machine doesn't seem to accept this device with port ( i tried with linux as main and win as virtual)? – Pragyan May 04 '20 at 18:28
  • you can run in any linux as long as persistence is large enough for compiling. if you have Laptop with Windows, use QPST instead – alecxs May 04 '20 at 18:31
  • I have tried qpst and qfli but everytime i get some error like fh loader failed or sahara failed. Mi flash tool also gives me errror i.e. cannot receive hello packets. So I will be using Linux Method but I have one doubt How would I know that I have successfully enabled edl mode? because in windows device gets connected to COM10 in non-EDL and COM3 in EDL mode. So, is there a similar way or linux will directly accept device in EDL mode only? – Pragyan May 04 '20 at 20:37
  • you can see in device manager if it is named Qualcomm HS-USB QDLoader *9008* (COM3) then it is connected in EDL mode. for linux i don't know. you have a 30 second gap after connecting, after this Sahara fails with timeout https://android.stackexchange.com/q/219810 – alecxs May 04 '20 at 20:46
  • @alecxs is 10gb persistence enough? my rom size is 3.37gb – Pragyan May 04 '20 at 21:40
  • @alecxs I tried flashing MIUI 9 using mi tool and it worked perfectly. Just want to clear something up! I selected clean_all&lock.bat while flashing but my bootloader is still unlocked. So is it OK or it can cause any problem in future or it is imperfectly unlocked? – Pragyan May 05 '20 at 14:08
  • it is recommended to keep bootloader unlocked, this way it is easier to rescue data (in case display is broken) – alecxs May 05 '20 at 15:37
  • What do you mean by display is broken? 2. But I selected clean_all$lock.bat so is it unlocked the correct way? or in edl mode that thing is not considered?
  • – Pragyan May 05 '20 at 16:32
