can someone take a look over this script? I want to add it in a sh file. When I connect my ethernet adapter I don't want enter all commands again. I just want to execute it from shell. Is this correct?
#!/bin/sh
ip link set eth0 up
sleep 1;
ip addr add 192.168.178.50/24 dev eth0
sleep 1;
ip route add default via 192.168.178.1 dev eth0
sleep 1;
ndc network create 1
sleep 1;
ndc network interface add 1 eth0
sleep 1;
ndc resolver setnetdns 1 8.8.8.8 8.8.4.4
sleep 1;
ndc network default set 1
When I enter the commands directly into terminal emulator ir works, when I execute the script with #sh filename.sh
I get error.
The second problem is, my file in root folder isn't here anymore after reboot.
/bin
can be a symlink: https://android.googlesource.com/platform/system/core/+/ff1ef9f2b10d98131ea8945c642dd8388d9b0250 – Irfan Latif Feb 13 '20 at 00:26
