Sub-directories in /sdcard/Android/data
or /sdcard/Android/obb
(called apps' private directories on primary external storage) have synthesized permissions based on directory structure. While public directories on the rest of the /sdcard
have fixed permissions. See details in Android's Storage Journey and What is /storage/emulated/0/?.
My answer to your linked question: How to bind mount a folder inside /sdcard with correct permissions? addresses the latter case i.e. bind mounting public directories which are shared with all apps. But private directories cannot be bind-mounted from external storage with fixed permissions. However using the same approach you can bind-mount every app's private directory separately.
Let's take example of Termux app. Its private directories (Android/data/com.termux
and Android/obb/com.termux
) are owned by the UID of Termux app assigned at the time of installation. Common ways to get UID value is to read from /data/system/packages.list
or do ls -ld /sdcard/Android/data/com.termux
or using stat
command. A simple approach is to bind-mount the directory as world-writable so that every app can write to it. But it's not a good idea to set such open permissions. So we go the Android's way; bind-mount a directory from external SD card using FUSE:
~# bindfs -u $(stat -c %u /sdcard/Android/data/com.termux) -g 9997 -p a-rwx,ug+rw,ug+X /mnt/media_rw/[UUID]/Android/data/com.termux /mnt/runtime/write/emulated/0/Android/data/com.termux
- For further mount options and details see the above linked answer.
- Replace
with /mnt/expand/[UUID]/media/0
if SD card is formatted as Adoptable Storage but data is not migrated.
- In the same way
obb
directories can be bind-mounted.
- If your device supports
sdcardfs
, the same mount should propagate to default
and read
emulated VIEWS as well. Otherwise if your device is older you can bind-mount the same way to other VIEWS.
- Some apps by default prefer writing private data to secondary external storage (i.e. external SD card), so you don't need to bind-mount their
data
or obb
directories.
touch
files/etc/passwd
and/etc/group
. – Irfan Latif Dec 19 '19 at 12:56bindfs
,/etc/passwd
and/etc/group
is no more necessary. I'm adding the link to new binary in linked answer. – Irfan Latif Dec 21 '19 at 17:23
