I am working on IMX8QM with Android 9. I needs to configure usb stick on static mount point.
Once USB stick detected,
create sda1
, after check I got:
mek_8q:/sdcard # df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1777588 1189664 587924 67% /
tmpfs 2918920 488 2918432 1% /dev
tmpfs 2918920 0 2918920 0% /mnt
/dev/block/mmcblk0p12 249828 58936 190892 24% /vendor
/dev/block/mmcblk0p14 9086336 967628 8118708 11% /data
/data/media 9086336 967628 967628 11% /mnt/runtime/default/emulated
/dev/block/vold/public:8,1 3918844 1311400 2607444 34% /mnt/media_rw/2A61-DD07
// Use UUID as stable name, if available std::string stableName = getId(); if (!mFsUuid.empty()) { stableName = mFsUuid; } mRawPath = StringPrintf("/mnt/media_rw/USB"); – VKS Nov 22 '19 at 06:53
