I am having a bit of trouble powering my phone I got a Lenovo A7000 plus which is the same as K3 Note version and this phone uses BL243 battery
Here is some information about the battery
Typical Capacity: 3000mAh/11.40Wh
Nominal Voltage: 3.8V
Limited Charge Voltage: 4.35V
and also I have a USB charger 5.0V 1.5A, I used the charger with another K3 Note phone I had, and I used it to power it up (using wires in place of the battery) it looked like it was all fine even after that when I connected the device to my pc it detected the device just fine also the k3 note's screen is damaged soo it won't show anything on it just boots up
so I wanna know is it possible to power my working A7000 plus with that charger using wires instead of the battery without destroying it
poqdavid
  • 1,323
  • 18
