I have a pre-compiled nmap binary for Android that was working properly and without error in LineageOS 14.1. The phone is a One Plus One.
Since upgrading to Lineage 15.1 (Android 8), the specific error I get is:
Socket creation in UltraProbe* sendConnectScanProbe(UltraScanInfo, HostScanStats, u16, u8, u8): Permission denied (13).
This is when nmap is run as the standard user, as root the phone becomes unresponsive and immediately crashes. I read somewhere over on SO that someone who was also attempting to open a socket was running into a permission issue as well, but successfully circumvented it by adding the user into these groups: aid_bt, aid_bt_net, aid_inet, aid_net_raw, aid_admin
It doesn't seem like this version of LineageOS has either groupadd or usermod, so that solution doesn't help me.
Did any changes occur between the two versions of Lineage that could cause this problem?
And how can I make nmap work again?
Firelord
  • 25,084
  • 124
  • 286
I don't have any experience with nmap and can't be sure why it worked with Android N, but Android has always been restrictive when it comes to socket access. I have been facing same issues at least from Marshmallow and onwards. ping is the common example.
Android's users and permissions management is quite different than Linux. Bionic libc doesn't support many sycalls provided by standard glibc, particularly related to NSS. Also, the related files /etc/passwd, /etc/group, /etc/shadow and others don't exist on Android the way they exist on Linux. So, the standard Linux utilities groupadd and useradd etc. cannot be used on Android unless the source is modified and environment is modified accordingly.
If you want to use a program compiled for standard Linux which needs capabilities CAP_NET_BIND_SERVICE, CAP_NET_ADMIN, CAP_NET_RAW etc., the program needs to be run by a user who is member of Android groups aid_inet, aid_admin and aid_net_raw. Even though the root user has apparently CAP_NET_* capabilities, socket syscall fails if it is not added to these groups explicitly. Most of the times only aid_inet suffices.
For instance, let's view capabilities of wpa_supplicant (process responsible for making wi-fi connections) on Android:
~$ su -c "getpcaps $(pidof wpa_supplicant)"
Capabilities for `21224': = cap_net_admin,cap_net_raw+ep
So, nmap won't work unless executed with its required capabilities. A capability is a subset of root permissions.
Terminal apps are usually already member of aid_net group (android.permission.INTERNET). However if it's not the case or you want to create a Linux type user on Android, follow on.
ADD LINUX USER ON ANDROID
NOTE: Device must be rooted.
On Linux, capabilities are assigned to a user (a user is a process id in fact, usually a shell) by some login mechanism, PAM modules being the most common. But there is no user login on Android, so we need to replicate that somehow. Lets create a Linux user, say "irfan" on Android.
Better is to use the UID of terminal app assigned at the time of app installation or you can use any unused UID like 6000.
Modify or create the files as below:
# /etc/passwd
irfan:x:10129:10129::/sdcard:/system/bin/sh
root:x:0:0::/data/local/tmp:/system/bin/sh
# /etc/group
aid_inet:x:3003:irfan,root
To login as user "irfan" with aid_inet as secondary group, use a Linux aware busybox su binary which regards /etc/passwd and /etc/group:
~$ id
uid=10129(u0_a129) gid=10129(u0_a129) groups=10129(u0_a129),9997(everybody)
~$ su -c 'busybox su - irfan'
~$ busybox id uid=10129(irfan) gid=10129(irfan) groups=10129(irfan),3003(aid_inet)
Please note the usage of su twice. First su is the one you get when you root your device. It's because su must be executed with CAP_SETUID capability. But normal Android apps run without any capability:
~$ capsh --print | grep Bounding
Bounding set =
The first su grants us that capability (and all other capabilities) as well as avoids the need to setuid on busybox su binary.
In the same way you can add yourself to as many groups as you want, everybody, sdcard_rw and so on.
SOURCE:
MAChitgarha
  • 123
Irfan Latif
  • 20,353
  • 70
  • 213
