The specific changes I attempted were to a database entry following instructions in this question: Possible to turn on Airplane mode with WiFi on only?
The changes to either row would take effect immediately but are reset following a reboot. The updated rows retain their row-id but revert to the previous/default data following reboot.
the exact command I used was:
adb shell settings put global airplane_mode_radios  "cell,bluetooth,nfc,wimax"
The following command would result in an exception where it is unable to find the key:
adb shell content update --uri content://settings/global --bind value:s:'cell,bluetooth,nfc,wimax' --where "name='airplane_mode_radios'"
I'm using Android 4.2.2 and the latest ADB available as of end of March.
Narfanar
  • 171
  • Does "settings put" not persist? I've been using it to modify my captive portal and navigation bar settings, and those do persist as far as I see. – Andy Yan Apr 28 '17 at 23:41
  • Also, it's suggested that you open a full adb shell and execute the command within, instead of doing everything in a single line. – Andy Yan Apr 28 '17 at 23:42
  • Confirm Yan's words: mine are persisted too. Your problem lies elsewhere. – Suncatcher Apr 29 '17 at 06:10
    I confirm that on my phone they are not persisted, on a LG G6 with Android 8.0.0. Opening adb shell didn't help. – Marco Lackovic Jul 19 '18 at 12:27
  • Having the same problem. My settings set by adb put don't persist after reboot, which is annoying. – Jay Zus Oct 02 '18 at 11:13
  • I can confirm the same as @MarcoLackovic on a Pixel 3XL with Android 9. Seriously it is (pardon my language) pissing me off that I have to plug my phone in to run adb commands after every reboot - and even if I don't reboot it STILL forgets it after a week or two. Seriously makes me wish I was a hermit dying in a cave sometimes that software engineers don't care anymore to quality like they did in the 1970s... (that's an Alan Kay reference on how a 1970s era computer could have instant response but 2GHz PCs take minutes to load) – Michael Jun 16 '20 at 07:15
