How do I enable System UI Tuner on my Lenovo Vibe K4 Note. It is not enabling on long press of quick settings button in the notification panel.
Asked
Active
Viewed 1,765 times
Long press and hold for a while ? – beeshyams Mar 23 '17 at 05:51
1It is possible Lenovo disabled it in their ROM... If you Google your model and System UI tuner, others have not been able to enable it either. – acejavelin Mar 23 '17 at 17:08
-1
if you are on marshmallow long press the "GEAR" icon for 5 seconds
(you should see a prompt that says ui tuner enabled)
then go to settings and you should see the ui tuner in the settings.
Link with tutorial here http://gadgetguideonline.com/android/android-marshmallow-guide/how-to-use-system-ui-tuner-in-android-marshmallow/
Evan
- 9
- 1
Considering that manufacturer can customize and enable/disable some features, are you sure this is possible on Lenovo Vibe K4 Note? – Andrew T. Nov 09 '21 at 05:16
@AndrewT. this is a valid point in this case i would suggest Rooting and running a custom Rom. some rom's for this device could be found here https://forum.xda-developers.com/f/lenovo-vibe-k4-note-roms-kernels-recoveries-o.5856/ – Evan Nov 10 '21 at 13:48
