For some reason, when I put the phone in landscape mode and enable the rotation lock, it just sets the screen to portrait mode and then locks the rotation. I want to be able to keep the screen in landscape mode, is there a way to do this? I am using a Samsung Galaxy S7, with Android Nougat and the TouchWiz launcher. I am happy to switch to Google Now Launcher if it lets me lock the screen in landscape though.
Asked
Active
Viewed 8,069 times
You can try the solution here if it is for a specific app(s) or try this Trigger: screen on; Action: force screen rotation> force landscape; constraints: Device orientation> landscape – beeshyams Mar 16 '17 at 03:24
The second option requires some tweaking.. Let me know if you are interested in this approach – beeshyams Mar 16 '17 at 04:17
grrr this happens with stock Android on a non-Samsung phone as well! – Michael Sep 25 '18 at 03:20
Modified from one of my previous answers:
Use apps like Ultimate Rotation Control - with proper settings, it seamlessly integrates with system rotation toggle, and on top of that you can enable/disable any rotation direction, force apps that don't usually rotate to rotate, and set per-app rotation behavior.
Andy Yan
- 9,554
- 17
- 31
- 56
