My Samsung Galaxy S6 fast charging cable has broken and I was wondering whether I needed to buy a cable specifically for fast charging, or just a regular media cable.
The fast charging plug socket isn't broken, it's just the cable.
Andrew T.
  • 15,988
  • 74
  • 123
MA40
  • 33
Fast charging is not related to the cable - the circuitry is in the adapter and device. That said you need to buy a cable that can carry higher amperage , allowing fast charging speed ( cable per se doesn't increase the speed but because it permits more power, speed is increased)
Thicker the cable, better it is ( thicker cables have lower AWG number )
Go in for a cable like Tronsmart cables at a price comparable with budget cables. These are 20 AWG thickness for charging (provide best charging) 28 AWG for data (thinner thickness doesn't affect data transfer speeds)
For technical details of a good quality cable see my answer here
I am not affiliated with the product- a very satisfied user
beeshyams
  • 40,739
  • 30
  • 119
  • 269
    Thanks for replying. So will the amperage affect the charging speed? – MA40 Mar 10 '17 at 18:29
  • Yes. If cable can't support higher amperage, speed is decreased. If the answer meets your expectations, you may accept it by clicking the green Arrow next to up / form votes – beeshyams Mar 11 '17 at 01:34
You'll want a quality cable, but the important part is the fast charging adapter itself, and if that's not broken or anything then you should be able to use any good quality cable.
DukeSilversJazz
  • 1,311
