Just a quick question. I have been trying to figure out the difference between Soft Reset, Hard Reset, Factory reset. If anyone could please help me to clarify the differences, it would be greatly appreciated, thank you.
A little bit of random information. So my phone was in my pocket, seems that it was reset (Turned off and instantly came back on) by the power button being held down for fifteen to twenty seconds, wondering if this is considered a Soft Reset, or Hard Reset, or if there really is a difference.
am restart
). Also, why does holding POWER key long enough still counts as soft reset? Isn't the circuit programmed to instantly cut power, similar to hard reset as you described it? – Andy Yan Mar 10 '17 at 00:13
