My phone was stuck in a boot loop too for no apparent reason. I was driving to work and suddenly the phone started rebooting. 3.5 hours later it ran out of battery. I have no idea why, but this is how I got it back to life...
I use linux ubuntu so I was able to get the developer tools:
sudo apt-get install adb android-sdk
sudo apt-get update; sudo apt-get upgrade
I also downloaded the latest image from google from:
https://dl.google.com/dl/android/aosp/hammerhead-m4b30z-factory-625c027b.zip
To recover the phone I performed the following operations from the bash shell:
1. Unlock the phone
fastboot oem unlock
me@ubuntu:~/Downloads/hammerhead-m4b30z$ fastboot oem unlock
< waiting for any device >
OKAY [ 47.200s]
finished. total time: 47.200s
This launches a prompt saying that it's waiting for devices. I then connect the dead phone using a regular USB cable.
The android device presents a menu saying asking if I'm sure I want to unlock the device and accept that the warranty might be void. As warranty on the Nexus 5 is void anyway, I can't see any harm in progressing.
2. Install the image file
Next I unzip the downloaded image file and cd into the folder:
me@ubuntu:~/Downloads/hammerhead-m4b30z$ ll
total 609328
drwxr-x--- 2 me me 4096 Dec 7 2016 ./
drwxr-xr-x 4 me me 4096 Oct 21 16:20 ../
-rw-r----- 1 me me 3199188 Dec 7 2016 bootloader-hammerhead-hhz20h.img
-rw-r----- 1 me me 974 Dec 7 2016 flash-all.bat
-rwxr-x--x 1 me me 845 Dec 7 2016 flash-all.sh*
-rwxr-x--x 1 me me 798 Dec 7 2016 flash-base.s
-rw-r----- 1 me me 574089971 Dec 7 2016 image-hammerhead-m4b30z.zip
-rw-r----- 1 me me 46581248 Dec 7 2016 radio-hammerhead-m8974a-2.0.50.2.30.img
As the phone is unlocked, I can issue the flash command from here:
sh flash-all.sh
As the script executes I see the following messages:
me@ubuntu:~/Downloads/hammerhead-m4b30z$ sh flash-all.sh
target reported max download size of 1073741824 bytes
sending 'bootloader' (3124 KB)...
OKAY [ 0.291s]
writing 'bootloader'...
OKAY [ 0.516s]
finished. total time: 0.807s
rebooting into bootloader...
OKAY [ 0.062s]
finished. total time: 0.112s
sending 'radio' (45489 KB)...
OKAY [ 1.547s]
writing 'radio'...
OKAY [ 3.123s]
finished. total time: 4.670s
OKAY [ 0.000s]
finished. total time: 0.050s
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
archive does not contain 'vendor.img'
wiping userdata...
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8144
Inode size: 256
Journal blocks: 32768
Label:
Blocks: 3351034
Block groups: 103
Reserved block group size: 823
Created filesystem with 11/838832 inodes and 93654/3351034 blocks
wiping cache...
Block size: 4096
Inodes per group: 7472
Inode size: 256
Journal blocks: 2800
Label:
Blocks: 179200
Block groups: 6
Reserved block group size: 47
Created filesystem with 11/44832 inodes and 5813/179200 blocks
Bootloader Version...: HHZ20h
Baseband Version.....: M8974A-2.0.50.2.30
Serial Number........: 02c6bc76215fcd2d
checking product...
OKAY [ 0.100s]
checking version-bootloader...
OKAY [ 0.100s]
checking version-baseband...
OKAY [ 0.100s]
sending 'boot' (9156 KB)...
OKAY [ 0.500s]
writing 'boot'...
OKAY [ 0.781s]
sending 'recovery' (10014 KB)...
OKAY [ 0.569s]
writing 'recovery'...
OKAY [ 0.824s]
erasing 'system'...
OKAY [ 1.297s]
sending 'system' (1020657 KB)...
OKAY [ 32.164s]
writing 'system'...
OKAY [ 69.195s]
erasing 'userdata'...
OKAY [ 7.820s]
sending 'userdata' (137318 KB)...
OKAY [ 4.511s]
writing 'userdata'...
OKAY [ 9.175s]
erasing 'cache'...
OKAY [ 0.628s]
sending 'cache' (13348 KB)...
OKAY [ 0.630s]
writing 'cache'...
OKAY [ 1.064s]
rebooting...
finished. total time: 130.023s
3. Welcome To Android instructions that you see on a new device.
Now it works.
FAILED (remote: flash write failure)
after trying a factory reset. I discovered I cant boot to a recovery image without flashing it (withfastboot boot recovery.img
) and it gives access to adb but that doesn't help since the thing can't flash or mount anything. – BiAiB Mar 06 '17 at 18:53
