If I used for charging sumsong for blackberry it not charge properly why? also is it effecting life of the battery?
Asked
Active
Viewed 31 times
-2
1Hey mate, you really need to fix your question, it's hardly understandable... – sharp Dec 15 '16 at 07:58
Not sure what you are asking, but a look into our charging tag-wiki most likely will answer your question. – Izzy Dec 15 '16 at 10:12
-2
It's recommended to only use a charger from the same manufacturer to avoid issues.
1Says who? Any references to your claim? I've never adhered to such a rule, and never had any issues. Several devices from different manufacturers, using their chargers cross-wise. Moreover, power specifications are normed with the USB connection. – Izzy Dec 15 '16 at 16:40
