I had an iPhone and am switching to Android now.
When I sign into my Gmail, will it show all my iPhone apps on my new Android device?
iOS and Android are different operating systems. As you probably couldn't run Windows applications on your iPhone, you neither can run iOS apps on Android. Alone for this reason they cannot simply "show up" on your Android phone.
Second, the Google account system isn't synchronized with Apple's iTunes (or the iCloud), so Gmail couldn't even know about them. Some might even come pre-installed with your new Android device.
There are means of migrating your data (contacts, calendars, photos, etc.) from your iOS world to "planet Android", see e.g.
But for apps, you need to find "new counter-parts":
<YourAppName> Android
, using the search engine of your choice, might be a good starter for that. My Android app listings can be of assistance as well. If you still didn't find anything, take a look at Where to ask for app recommendations? and follow the advice there.Some of your iOS apps might allow to export their data, and their Android counterparts might allow to import them then. But mostly, you will have to start from the scratch.
Have a good start with Android – and in case of trouble or missing information, you already found a good place to ask!
