I was following this tutorial in order to resize my screen (or "deactivate" a small part from the bottom of it): https://android.stackexchange.com/a/113782/191822
As describes above I tried tried it with ADB. I'm using Android 4.2.2, which is probably the reason why the following command doesn't work:
adb shell wm overscan 0,0,0,100
/system/bin/sh: wm: not found
Replacing wm by am didn't work either:
adb shell am overscan 0,0,0,100
Error: Unknown command: overscan
Does anyone know how to accomplish that with Android 4.2.2
I'm working on Ubuntu 16.04
EDIT: ok, I've come so far to notice that the command I have to use might be something like:
adb shell am display-size
e.g. (from 540x960 to 540x700)
adb shell am display-size 540x700
However, this will resize the screen on the top and the bottom. I couldn't find a way to only remove a part of the screen from the bottom withouth changing the screen position on the top.
Mojo Dodo
  • 41
