Let's say my phone is out of battery, and has turned itself off. I get to a charger, and connect it. Maybe I need to make an urgent call. But my phone refuses to boot until the battery is at 5%. It only takes like ten minutes to get to 5%, but still, I'd like to remove this limitation.
Some phones (and other devices) can even boot without the battery as long as they are plugged in, so I don't reckon it should be technically impossible to boot my phone with an empty battery if it's plugged in. The phone should be able to power itself from the charger alone, if nothing else.
My charger gives plenty of power, enough to use heavily and still charge at the same time.
I reckon the reason they have created this limitation is because if the user then unplugs the phone while the battery is at 1% or something, the phone may not have sufficient time to shut itself down properly. But I'm aware of that danger, and I still want to have control of this myself.
Is it possible to remove this limitation of 5% battery before boot?
To clarify, when I'm using the phone (and it's not plugged in), it goes all the way down to 0% without automatically shutting down. So there doesn't seem to be any limitation there. But if I then connect it again, that's the limitation I'm talking about. I then have to wait until it gets up to 5% before I can boot.
My phone is an Asus Zenfone 2 running Lollipop. It's rooted and I have Xposed Framework.
beeshyams
  • 40,739
  • 30
  • 119
  • 269
Fiksdal
  • 1,211
  • 60
  • You seem to be asking two questions 1. Remove limitation of 5% ( you have trained correctly). One more reason is it is very bad for battery health 2. You want to use the phone connected to charger before it is charged to 5%. Breaking up the question may help, unless i read wrong – beeshyams Aug 06 '16 at 19:21
    Related http://android.stackexchange.com/questions/95161/how-to-automatically-shutdown-below-certain-battery-level – beeshyams Aug 06 '16 at 19:25
  • @beeshyams Removing the 5% limitation and using the phone before 5% is the very same thing, no? The phone doesn't shut itself down when it gets to 5%. It goes all the way down to 0% and then shuts down. The limitation I'm talking about is during charging. I've added further clarification to the question. BTW, what do you mean by "trained correctly?" – Fiksdal Aug 06 '16 at 19:33
  • Sorry typo , meant "reasoned" +1 – beeshyams Aug 06 '16 at 19:40
  • @beeshyams If (hypothetically) I was able to remove that limitation, would it be bad for battery health to boot and start using the phone when the battery is at 0%? – Fiksdal Aug 06 '16 at 19:45
  • Absolutely disastrous.. Over/under charging battery is with respect to voltage levels and IIRC, even a slight under charge can reduce battery performance 10% – beeshyams Aug 06 '16 at 20:07
  • @beeshyams But the phone would be plugged in, so wouldn't the phone just take power from the charger rather than the battery? – Fiksdal Aug 06 '16 at 20:09
tl:dr Mobile devices unlike laptops are not designed to run off the charger, without a battery (there are exceptions of some devices, way back). A fully discharged battery is as good as no battery, so connecting to charger will not power up the device. Unless the battery is charged to a minimum level, it cannot be used to power the device
  • A battery is said to be discharged when it reaches 3V level ( also called deep discharge) . At this voltage 95% of the energy is spent , hence the mobile is designed to power down before it reaches this level
  • Battery charging has different stages with corresponding voltage levels as shown in figure below. The current fed from charger in the initial stages is very low (trickle charging , represented by 0.1 C, where is the Charging rate- see figure). It is only after the battery is charged above 3V, it can function. This accounts for the time it takes to charge to 5% and be able to power up the device (Not sure of the exact voltage level)
  • Additional factors that come in play for not permitting battery to operate before 5% :
    • There is a safety margin that is built in , since deep discharge followed by full charge (3.9 V) would cause undue stress and is not recommended
    • Powering up a mobile from switched off state requires significant power (you would typically see at least 1 to 2% drop). If the battery voltage falls to below 3V due to this load, your battery would again shut down
    • Increasing charging rate (to reach level required for battery to operate) is a physical hazard, as the battery may explode
To sum it up, Li Ion or Li PO batteries have a bunch of physical security needs to be met. This combined with battery longevity and performance considerations, safeguards need to be in place - shutting down at low battery % , allowing the battery to reach required voltage levels is a part of the big picture. Understandably, given the mobile device penetration , nobody would like to cut corners (despite that one hears batteries exploding, recently in news)
beeshyams
  • 40,739
  • 30
  • 119
  • 269
