Actually I used Micromax charger instead of Xolo charger. I have xolo era x phone. My phone gets switched off if I keep it idle for 4 min. Why it is happening?
Izzy
  • 91,166
  • 73
  • 343
  • 943
vikash
    Welcome to the Android Enthusiasts! Please take a look at our charging tag-wiki and especially check the "Chargers/Cables" section (as for the title of your question). Concerning the question body ("Why is this happening?"), I can't tell, sorry. – Izzy Jun 26 '16 at 12:20
  • Don't go just by the specifics in question. See the answer which is generic while dealing with specific case. Since you didn't specify the charger details you can check for yourself but my guess is that charger is not the problem for you. What could be causing it if not charger is not easy to answer as Izzy also mentioned above – beeshyams Jun 26 '16 at 13:34
Your phone can be affected by the charger if the wattage and/or the voltage for the phone is not the same for charger. It could also be a hardware issue like: a battery, certain apps, bad part, etc...
Yes, the charger affects the phone (battery). For example if you charge a smartphone with a charger made for a tablet (which requires more energy) the phone charges faster, but its battery will get damaged when you do it too often. On the other hand, when you use a charger that is too weak, it might isn't even recognized by the phone and charges very slowly, if it charges.
Namnodorel
  • 294
