I want to modify a file under /system. The problem is that is read-only, and even with root I cannot set it as read-write.
I've tried the following:
Some useful informations:
  • The device is a Redmi 3
  • Using android 5.1.1, on MIUI 6.4.7 (china developer version)
  • I have root access, and enabled it for the apps mentioned above
  • Bootloader is unlocked
  • No SD card
  • Output of mount | grep system: /dev/block/dm-0 /system ext4 ro,seclabel,relatime,discard,data=ordered 0 0
I would like to manage the /system folder directly from the phone. I'm pretty hopeless, I've tried googling 2 hours for a working solution. Thanks in advance.
asdm_ita
  • 71
I've found the source of the problem asking in the MIUI forums, the boot image will not accept a modified /system.
You have to use the adb interface: adb devices then adb disable-verity.
Disclaimer: I'm not responsible for any damage caused by these operations.
asdm_ita
  • 71
    Unfortunately this only works on USERDEBUG builds. Still looking for what works for stock builds. – SAGExSDX Dec 23 '16 at 02:39
As suggested by user aalaap here, disabling Mount Namespace Separation setting in SuperSU solved this issue for me on ZP999 and SuperSU 2.82 SR5.
Firelord
  • 25,084
  • 124
  • 286
