I have a rooted HR933 tablet running Android 4.4.2, and an embedded device with a Wi-Fi access point but no Internet access. I need the tablet's browser to be able to reach the device's web server via Wi-Fi, and also connect to the Internet via mobile data at the same time.
Super Download (see How do I connect to a wifi ap and 3g network simultaneously?) will not work because I need to browse, not just download files.
I'm trying to enable the Wi-Fi and mobile network adapters simultaneously as described here:
# enable dual-networking:
pkill dhcpcd
svc wifi disable
svc data enable
netcfg wlan0 up
cd /data/misc/wifi/.
wpa_supplicant -B -Dnl80211 -iwlan0 -c/data/misc/wifi/wpa_supplicant.conf
dhcpcd wlan0
ip route add x.x.x.x via x.x.x.y # add any desired local route
The problem is that as soon as I do svc wifi disable
, the wlan0 adapter disappears. The script above implies wlan0 is still available after disabling Wi-Fi, but on this tablet it isn't:
netcfg
tunl0 DOWN
lo UP
ifb1 DOWN
ifb0 DOWN
sit0 DOWN
ccmni1 DOWN
ccmni0 UP
ccmni2 DOWN
ip6tnl0 DOWN
So when I try netcfg wlan0 up
, I get action 'up' failed (No such device)
EDIT:
After additional trial and error I've found that I can briefly get the dual network setup to work before the tablet disconnects itself from the embedded device's access point:
svc data prefer
makes the mobile connection data preferred.- Manually enable wlan0 with
netcfg wlan0 up
. - Connect to the device's AP via the Wi-Fi UI on the tablet.
I then have about 90 seconds where I can browse the embedded device's web server and pull up Internet websites in separate Chrome tabs at the same time. After that time the tablet disconnects from the device's Wi-Fi and wlan0 is shown as down with netcfg
. My logcat output includes this:
D/WifiStateTracker( 682): New state:CONNECTING, mLastState:CONNECTING
D/ConnectivityService( 682): ConnectivityChange for WIFI: CONNECTING/CAPTIVE_PORTAL_CHECK
D/WifiWatchdogStateMachine( 682): Network state change CAPTIVE_PORTAL_CHECK
D/ConnectivityService( 682): Captive portal check NetworkInfo: type: WIFI[], state: CONNECTING/CAPTIVE_PORTAL_CHECK, reason: (unspecified), extra: "EMBEDDED_DEVICE", roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false, simId: 0
D/ConnectivityService( 682): Tear down low priority net WIFI
"EMBEDDED_DEVICE" is substituted for the actual SSID. That last line would seem to indicate it's a "low priority" network, but there doesn't seem to be a way to change its priority; it's also the only "known" network on the tablet.
