I'm looking for a way to boost the headphone output of my Moto X (2013). I have rooted it and installed Alsa Mixer so I should be able to run shell scripts and modify it.
The thing is.. I can't find any good guides for this.
What I'm trying to do: - Boost the volume using a compressor (like radio stations tend to do) - Maybe apply a limiter after that just to be sure I don't blow up my headphones.
Can somebody help me plz?
REJH
  • 351
  • Welcome to the Android Enthusiasts! Have you already tried our powerful search feature, and checked e.g. for volume boost? Was your solution amongst the results? :) – Izzy Nov 28 '15 at 12:28
My suggestion is to install Viper4Android. You can increase output by (as I recall) 8dB, and besides that, you will get a lot of options to adapt the sound to get the best output. Using it for a couple of years and still haven't found a better alternative.
Chapz
  • 752
  • Thanks I stumbled upon this myself yesterday but wanted to try it for a littke before answering my own question. It's a bit of a hassle to get it working (softbricked my phone because I forgot to restore build.prop file permissions) but once it works it really works! – REJH Nov 29 '15 at 13:10
    In settings, set the UI mode to Expert, you will get all the options available. If you stay in default mode much of the options (including the output dB strength) are hidden. – Chapz Nov 30 '15 at 22:50
