On my "8GB" device (which I believe doesn't have an extra physical sdcard installed (I have to unscrew it to see that)) I have the following df output:
Filesystem Size Used Free Blksize
/dev 402M 32K 401M 4096
/mnt/secure 402M 0K 402M 4096
/mnt/asec 402M 0K 402M 4096
/mnt/obb 402M 0K 402M 4096
/mnt/shm 1024K 0K 1024K 4096
/system 503M 297M 206M 4096
/data 6G 344M 5G 4096
/cache 495M 186M 309M 1024
/device 7M 1M 6M 1024
/storage/sdcard0 6G 344M 5G 4096
I am confused though, because /data and /storage/sdcard0 are exactly the same (suspiciously the same!), but as I understand it though: /storage/sdcard0 should refer to an external physical sd-card, and not refer to the same place as /data. What is going on?
/storage/sdcard/
still refers to external storage, but it's emulated. This question might be helpful, or even it might be a duplicate. – Andrew T. Jun 24 '15 at 09:37/storage/sdcard0
is a symlink to/storage/emulated/0
. Your device probably has something similar. I don't think the exact mountpoint matters (i.e sdcard0 vs emulated/0), as long as they all point to the expected location. – keepcalm Jun 24 '15 at 12:33
